Chances are that if water is coming out of the bottom very rapidly a clamp or hose has come loose off of the tub or pump. Also, since that is a stackable unit it should be very easy to check. Tilt the machine back and there should be 2 screws or fasteners holding the front panel in place. If it is not a hose the only other thing would be a crack in your outer tub. (It would have to be one heck of a crack too).
SOURCE: washer is leaking water at bottom
You should look at the machine's bottom first- try to find out from where water leaking from. In most cases it is the pump.In such a case it should be replaced. Good luck!
SOURCE: Leaks water
Okay, to check for your source of a leak, start by removing the 2 screws on the lower front panel of the machine. This will let you see inside. As you are running the washer, watch where the water is coming from. If from the front, you may have a hole in your boot (the black rubber up front) If so, you may need to replace the boot (the part comes with step by step instructions). If coming from the middle, your tub seal may be going bad. A quick fix is tighten the 12 or 14 bolts that go all of the way around your tub. This will only be a temporary measure. The tub will have to be taken apart and the seal replaced. (this is a 1 1/2 hour - 2 hour procedure for 2 technicians) If it leaking from the rear, you may have a bad tub bearing. You can remove the back panel to be certain, but usually a bad bearing will be accompanied by a roaring noise durring the spin cycle. As for the dryer leaving brown marks? Usually the front seal has been dammaged. Run your finger around the front of the drum (where it meets the front panel) the gap should be about the same all of the way around. If it is not, you may need a new front seal. (this is much cheaper and less time consuming on the dryer compared to a seal on the washer)
SOURCE: Washer will not drain water and is leakiing from
HI, this leak is caused by the back up or clog in the drainage system. use the following text to troubleshoot this issue.
Check to see if there's something stuck inside the pump or the drain
hose connected to the pump (pump is usually located at the bottom
and towards the back of the washing machine).
If the drain line isn't clogged, you may have a problem with the
water pump such as a frozen pulley or a broken impeller. If that's
the case replace the water pump. Note: if you have a belt driven
washer, check the belt(s) for cracks, as this would be a perfect
time to replace the belt(s) if needed.
SOURCE: Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
SOURCE: My washer doesn't wring the clothes fully.
It's not spinning fast enough because of a loose or worn belt on the motor. Post back with your model number and I may can find a diagram of your washer to help you.
