RIM BlackBerry Bold 9700 Smartphone Logo
Posted on Sep 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My blackberry 9000 bold shows jvm error 102 plz guide how to fix it .its not woking only white screen with this error shows when i on the phone.
Anonymous
Level 3:
  • Master 358 Answers
  • Posted on Sep 26, 2010
Anonymous
Master
Level 3:
Answers
358
Questions
0
Helped
78292
Points
1206
Hi, i think if you try resetting it, it might work .
There are three ways you can reset the black berry phone.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Hope this Tip helps.
1helpful
I have a blackberry 8330 when i put on the phone . theres a white screen that says jvm error 102 reset
i have a blackberry 8330 when i put on the phone . theres a white screen that says jvm error 102 reset
I have an jvm error 102 on my blackberry 9700 bold, there is only in the screen : jvm error 102 reset, can you help me, thnx
There occurred some OS error in your device. Try to re-install the OS
Regards
Vineeth K.
Aug 05, 2010 • Cell Phones
1helpful
I have jum error 102 onn my blackberry bold 9000
Your mobile OS (operating system ) has been damage , you have to re install your OS with desktop manager
Download the latest OS and desktop manager from RIM side (https://www.blackberry.com/Downloads/entry.do?code=577BCC914F9E55D5E4E4F82F9F00E7D4 )
2answers
Jvm error 102
reload the software using desktop manager
My blackberry bold 9000 screen is white. the message on it reads 'JVM Error 102, reset'. how do i fix this?
You'll need to reload your BB software. Get the BDM (Blackberry Desktop Manager) on https://www.blackberry.com/Downloads/entry.do?code=A8BAA56554F96369AB93E4F3BB068C22, after downloading run the setup and after completing this step. Connect your blackberry to your computer and open the BDM (Blackberry Desktop Manager). The application would recognize your blackberry, when it shows that your smart phone has been connected, you can now run the software. Make sure your computer is connected to the internet.
Run the software and allow it run. This process may take few hours to complete once done it would automatically reboot your phone and you are good to go.
Thanks
1helpful
How to reset if JVM error 102 is hown on the
Try to replace the firmware / system software of your BlackBerry Boild 9700 to fix your initialization errors. The latest BlackBerry Bold 9700 system software is available through here.
I have a blackberry bold it has a jvm 102 error how can i fix this?
http://www.howardforums.com/archive/topic/1005876-1.html
If you go to the page above then there is detail about the error.I know itsnot exactly the same phone , but will give you a insight.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
