Possibly it is bent see the video Dyson DC25 DC29 Releasing jammed wand Official Dyson video
SOURCE: Dyson Refuses to Honor Warranty
Hi. I have been repairing Dyson machines since they first came out. DO NOT PAY FOR A NEW CLUTCH. I can assure you that both clutch belts can be replaced. Its A tricky job & can take some time to do. Its more cost effective for a shop to fit a new clutch at your expense $150 Clutch Belts are readily available in the UK you can purchase belts from numerouse sites for approx $10 postage to states $3 to $5 saving you a small fortune. If you want to know how to fit the 2 belts I can sell you A manual for approx $11 Or contact me at [email protected] for more information.
SOURCE: Cannot Assemble Dyson DC17
press the button on the side of the wand that detaches it from the main vacuum and try pushing it into the hose, let me know if this doesn't work
SOURCE: Dyson Ball Vacuum
At the bottomor end of the wand there is a curve hose. That is removable. Pull the wand out all the way and turn that curved piece down. It slides out. There is a little channel. It should come right off. I've been there. Let me know if it helps.
Jacquie
SOURCE: HOW DO I RELEASE THE WAND ON THE DYSON DC 17?
It's sometimes hard to remember which of these models is which! You should have the machine in the upright position, then I think all you have to do is grasp the top of the wand and just pull it upwards. I hope this helps.
SOURCE: dyson dc25 animal: cannot remove the telescope
The hose is getting twisted on the machine and so the wand gets stuck in the hose.
1) Pull the wand out as far as you can - if you can pull it out completely, separate it from the hose and apply baby powder to the
metal rod. Stretch out the hose and unwind it. In the future, separate the wand and unwind/stretch the hose after use.
2) If you can't pull the wand out all the way, remove the canister/dirt bin from the front. Look for a gray button with 7 vertical
lines/grooves on it (it'll be just above the ball on the opposite side of the bottom hook that you wind the cable around).
3) Push the button and at the same time pull the hose out from the bottom by pulling on the hook - this will release the gray hose
from the machine. Take it off of the machine if possible (the bottom of the wand may stop you from doing so - if it does, try to pull
the wand out until you can release the hose from the bottom)
4) Pull and stretch the hose out and pull the wand at the same time - separate the wand from the hose and unwind the gray hose and
stretch it out. Rub baby powder on the metal rod of the wand and in future, disconnect the wand from the hose and stretch/unwind the
hose after every time you use the wand.
