AOC LCD TV's: 17.0" LCD Flat Panel Display - FP720 Monitor Logo
Posted on Jul 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi. I would be very oblige if some on can guide me on how to set up TV remote. I am using a Technics TV, with build in DVD and freeview, However the remote that came with it has been broken and there for i purschased a new unversal remote control OMEGA, which needs to be coded before the tv starts functioning and this the problem i have and i hope somone from Fixya would resolved for me....... Many Thanks
Jose Ma DM.
Level 3:
  • Master 540 Answers
  • Posted on Nov 14, 2018
Jose Ma DM.
Master
Level 3:
Answers
540
Questions
0
Helped
177105
Points
1776
Hi, in the following link you can find Omega user manual to set up devices codes:
https://content.abt.com/documents/6074/mx650_man.pdf
For AOC TV, codes can be 197, 004, 112 or 058.
1 Related Answer
Anonymous
  • 1779 Answers
  • Posted on Oct 31, 2009
SOURCE: tv acts like its trying to change channels. Voice distorted
I would suggest returning it for exchange.
Can any1 help with my ikasu tv remote code
http://www.rockabilly.net/files/manuals/URC-7740.pdf
Download the manual and if your model is not listed follow the section called search method and the set will do it for you.
Let me know if this helps.
1helpful
Need a code please for tecknica tv 25-56D
1. Yes, a universal remote will work just fine. Buy a universal remote and then one by one, try the following codes until you find the correct one: 000,001,004,005,008,009,013,042,051,053,058,105,109,170,174.
2. Maxell is a recording disk and often times cannot be played on certain DVD players.
Need the remote code for a meos dvd121b 12.1 portable tv / dvd player as the one that came with the unit is very small and would like to use bigger multi function device. regards - Graham
What's the remote code for the meos DVD 121b 12.1 portable tv/ DVD player. The buttons on that remote seem to freeze when I'm using the freeview don't know why buttons that dont work in freeview are here are some of them the setup button channel change and epg button this is with the remote control I use.
Lost remote
I'll sell you mine if you want it's never been used yet.
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
1helpful
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
1helpful
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Chris..
1helpful
3answers
Remote control codes for freeview and dvd recorder
According to the booklet you have to enter the code 119 for a Goodmans TV, however it does not work with my Goodmans portable TV and even quick search / autoscan doesn't find the TV.
3helpful
2answers
Wharfedale DVDRHD400 Set up Issue
Hi I had the same problem. The answer is to use a scart lead on the freeview box and connect it to the input/output scart on the DVD. Then connect a scart lead from the TV out on the DVD to the TV. You then press Video source on the DVD remote until 'scart' is displayed to pick the freeview channels. Hope that helps
Top AOC Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
