SOURCE: disable network access to registry!!
are you running winxp os? if so go to control panel click on administrative tools then on services, look down the list until you see what your looking for and disable it. I hope this helps.
SOURCE: blue screen on my inspiron 6000
your hard disk has some eror it must need fixing.u can format your harddisk with win xp recobery disk.
SOURCE: I have received an error code of 0F00: 133E. What does this mean
sounds like your HDD is gone, however if you can get it to safe mode by tapping F8 while booting, you can perform "chkdsk /r" on C:\ drive, just to repair bad sectors..
SOURCE: I have a Dell Inspiron 1501 and the following code
Those are Hard disk drive error codes, you will need to replace the hard disk drive.
Here is a selection of possible replacement drives:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010150380%201035915133&name=SATA%203.0Gb/s
