Jfinch sorry it took so long to answer. If all the lights are blinking check to make sure that the freewheel levers are in drive mode. then check (if you have the power seat option ) that the seat is all the way down, and finally the problem could be in the controller check to make sure that the cable connection to the controller is well seated. If all these are correct and you still get the error then you will have to contact Hoveround tech support to find out what else you can do. They might have to send out a tech to look at the chair. Sorry I couldn't give you a quick fix Hope this helps you
The number of bars that are blinking will also help to indicate what the problem is. Fault codes are located in the back of the owner's manual.Try doing the brake reset as previously suggested or the lock out sequence noted in the manual; call it in if neither of those steps help.
