SOURCE: Dlink Di-514 slow
hi, Need to change teh MTU settings in your router.once you will change it,, it will work
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
SOURCE: Cannot connect wireless on Advent 4311c using xp
Glad you could work this out, happy everyone directed you to the correct solution.
SOURCE: After replacing Cable Modem, D-Link DI-524 Wireless will not work
Hi Serina - first of all: what a great post! Very detailed and professional. I just have to say that, since I'm reading here lots of "interesting" questions sometimes.
To your problem:
Apparenatly the router does the "routing" part well, since you can access the internet via cable. The problem is the wireless access point.
Your IP output looks actually good - I can't see any problems with the values. What I would try to do is to disable IPv6, since it is only used on your internal LAN and not yet implemented on the WAN side. This page (link) has a good write-up on the how-to. Don't do the registry part - just disable it in the Properties window.
I had noticed conflicts on computers where IPv4 and v6 were installed simultaniously.
Try it and see if that corrects the problem. If it does not, please let me know.If you have any more questions, just come back here and leave a comment - I'm happy to help.
SOURCE: D link router connection Hi I have recently bought
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
