I am having a problem with my device archos 605 wifi. I put the device on demo firmware and since it does not work. A dark screen appears when i turn on saying Most features of firmware disabled. I tried many to repair and format by installing the new firmware from archos.com, but still does not work. I tried to contact the company but no reply, very bad customer service. Please notify me if you know how to repair.
Hitesh_rao - the reset button is at the bottom by the USB and docking ports. Tiny hole, need a pin or paper clip. Once pressed, just switch it back on.
This may be a stupid question, but when trying to configure the TV IR controller function and entering the relevant codes for my TV's, it asks 'did the TV switch off = Yes/No?'
None of my TV's switch off and then I cannot go any further with the config. Is this right? I have logged this with Archos FOUR times now, and they just respond with 'the controller does not control your TV'. I am fully aware that it is not a TV controller, but then why does it want to switch off my TV during the config? I just want them to answer that question.
Somebody please help!
Recovery Code 104 for 605 wifi keeps coming up on the archos screens. i need to know what i should do to fix the problem. can someone walk me through step by step on how to reformat the archos
I had this
press the reset button and it should go back
Mine is doing the same thing, let me know if you find a solution
dont exactley have the same prpblems but i have currently got a prob with my archos605 wifi got white screenwith recovery update but what i wanted to say was that i rang them on the saturday about the prob thay werevery helpful within a day or twosent me email with details for repairing ive heard that there c/s is a bit rubbish but so far cant complain the number i rang was a 02 no apperently in holland you should have the number withyour item good luck or is it me that needs it stil awaiing the return of
HI YEP SAME THING HAS HAPPENED TO ME,
is it possible to go back to an older firmware version? Problems started when i installed 2.0etc..
where is the reset button???
