My hdmi output on my ps3 does not work. i have a brand new hdmi cable and 42 in tv. does the hdmi output need to be repaired or can it be replaced?
By you saying that you have a new cable & tv, I assume you had the console conected tru composite before (red, white & yellow rca cable). This is what you need to do: Connect the PS3 to the tv with HDMI cable only, do not use the composite cable at the same time, reset your PS3 by pressing and holding the power button, when the power is off, for about 7 to 10 secconds, it would cicle from power off, on, then off again, it would also give you 2 sets of beeps, after the power is off, turn your tv on, make sure you select HDMI input on it, then turn your PS3 on, the console would set itself to the best resolution available on your tv. Give it a try!
didnt work
HELP!!!!!!!!!! PS3 is not recognizing my HDMI connection!!!!!!!!! I've tried the on-off thing and that doesnt seem to work.....Geeeze it seems that this should not be this difficult.
WHEN YOU RESET THE PS3 DID IT FIX YOUR HDMI OUTPUT? I HAVE THE SAME PROBLEM
