SOURCE: Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
SOURCE: I have Transcend MP850 8gb, i am not able to
Download the .mtv converter s/w from the Transcend site. This is available for MP820. And download any flv to mpg converter software from google. And also you should download the codec for QuickTime and RealPlayer from the corresponding sites. Since without this codecs we can't convert the mpg to mtv format using the MP820 mtv converter. If you already have the mpg files then you can easily convert that files into .mtv format by using the MP820 mtv converter. Hope this helps. Thank you.
SOURCE: Transcend hard disk issue
The problem is the usb ports in your pc. You know the drive works and is properlly deteced on the laptop so you can ignore that.
IF you can try other usb devices in your pc usb ports and see if they work.If they don't at all then you either have dead ports or drivers are missing. You should see them listed under control panel system hardware.
If they work then I would wonder if the usb drive you have requires a differant usb port than what you have. There is a type 1 and 2 and type 3 which has just come out so we can ignore that one. A type 1 is slower and cannot power devices usually. A type 2 is faster and can power some devices. I don't know how old your pc is so it could be hardware, either failure or drives. You should also makre sure you have the service packs installed for windows. Sp3 is the latest version. There were some changes to the way usb devices were deteced in Sp2 if I remember correctly.
SOURCE: I have TRANSCEND D33193 4GB
i have 8gb pendrive i put it into the pc but it is not dectected
