The color is off. There is double of every thing. How do I fix this problem
I think this is a convergence problem
If you don't
have any repair experience my suggestions can only be useful to get a
repair estimate, or in order to get more familiar with these kind of
problems, impress your local repair person etc..
actually tat effect will be in some red color..(assuming tat its of red color)--ur case its blue i think.. this is a equivalent solution of red..
switch to test mode to check the red cross hair compared to the green or
blue - if it seems out of focus, open the set and mark the position of
the lenses. Then adjust it to tighten the line.
Find out why the Red has shifted(pin trouble). look for bad solder
joints on that board. Its also Possible that you have a failed
component.
Try re soldering the STK Output IC's very carefully.
In a worst case scenario , you may need to change the STK that controls the Red Convergence
Yank out the convergence board(the one that has several
controls) on it, then you will find a few controls that have RED PIN
(whatever). on them. Adjust them until you get it right
Hi
you have defective convergence correction amplifier! you need a professional technician to fix it! if you need a prof.tech near you just visit www.fixya.com then go to REPAIR SERVICE and simple enter your zip code.
thanks.......
The convergence ICs and maybe some resistors will need to be replaced. The ICs will be the more expensive parts, the resistors are very cheap and I believe Radio Shack will be able to get you everything that you need. If you have any other questions, I would be glad to answer them. Don't hesitate to ask.
thank you and good luck
you cold try cleaning the lenses within the tv to fix this also first before switching out the ICs
If your picture is bowing, then you have bad convergence amplifiers, is there anything else that you did not tell us at first that may help
Step1
Unplug the TV from the power supply. Never
undertake any type of repairs on electric equipment without first
disconnecting from power. Take care in handling any electric parts, as
some may contain a residual charge that can shock you.
Step2
Remove screws from the back cover and connection area of the TV. Be
sure to put them in a safe place, or on a piece of paper with notations
for where each one fits in the television.
Step3
Gently remove the back cover. Locate the mirror and three projection
“guns,” as these are what you want to clean eventually.
Step4
Use a camera lens cleaning cloth (or other very soft and gentle cloth)
to clean the mirror and lens. Gently remove any other dust before
closing the TV.
Step5
Replace the back cover and screws. Plug back in the power supply.
Step6
Turn on the television. Check to see that everything works correctly and that your picture is now clearer.
I don't think this will solve your problem but it should help, like I said before you will need to replace a few parts
Download Toshiba 50HX81 User manual at
http://www.nodevice.com/user_manual/tosh...
This does not address my problem
My tv had a red curved line near the bottom of the picture and it is double. How do I fix it?
What are the directions for cleaning the lense?
How do you adjust the convergence cross bars? I can adjust numbers 1 4 6 & 9 but not 2 3 7 & 8 I can't get the colors to come together
