The door is not locked after 6 trials then the Central Control Unit (CCU) will enters a failure mode and the digital display flashes FdL. This is a door lock failure and the only viable solution is the replacement of the door lock and switch assembly.
Disconnect
power to the washer and open the door. Remove the door gasket retaining
hoop by stretching apart the retaining spring at the bottom of the door
opening.
Gently peel the part of the door gasket near the door
lock and switch assembly off the lip of the door opening outer lip.
Remove enough of the door gasket to access the door lock and switch assembly
behind the front panel.
Remove the three screws securing the door
lock and switch assembly to the front panel and slightly lift then pull
it back off the front panel and out of the out of the washer cabinet.
Connect the wiring harness to the new door lock and switch assembly one at a time then install it back in place behind the front panel.
Secure
the door lock and switch assembly then put the eased part of the door gasket
back over the outer lip of the door opening. Check that
the door gasket is properly seated before putting back and securing the
retaining hoop around the lip of the door opening and the door gasket.
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
