Turn the main power to the unit off, leave off for about 20 seconds then turn back on. Unit should restart. The blinking light is a fault light that can be reset by turning main power off. Most times it will restart no problems but if the fault re occurs there is a problem with the unit itself. If the fan starts and runs for around 4 minutes on cooling mode then stops and blinks there is a problem with the outdoor unit.
Usually Sony and LG Blinking Codes are the same. Here is what I have.
Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
One blink - not used for the self-diagnosis
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
HI, the power unit is experiencing some difficulties due the an overheating issue. if the light is turning yellow at any time, this will confirm a overheating issue. Now, if the light is simply turning red and, powering off then system with a red blink, this will confirm a power unit failure. you will need to replace the power unit in this case.
Contact your nearest Sony repair shop of, contact Sony manufacture for this repair.
NOTE(If its a simple overheating issue, you can purchase a cooling device to heel this issue)
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply.. if in dry mode let the unit run for an hour and it will stop blinking ..
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
