Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Dishwasher
filters are important to catch food particles and other debris. The
dishwasher cleans small portions of food from the dishes, cooking
pans and silverware. These particles must go somewhere. The drainage
system on the washer may clog if filters are not present. Most Maytag
dishwasher models have two types of filters, "Coarse" and "Fine." You
should clean the "Coarse" filter after two or three wash loads. The
"Fine" filter can wait for a cleaning for about 300 loads or three
months.
jQuery('.intro .thumbnail').each(function(i,e){
jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); });
Difficulty: Easy
Instructions
Things You'll Need:
