Call service c3100
This code relates to the mainboard, check the cables, also make sure you update the machine firmware.
This error code relates to the scanner carriage lock, which is still locked when the copier is turned on. Switch the device off and then unlock the scanner carriage lock under the platen cover and then reboot.
Unlock the scanner locks 2 nos.
Esse c?digo siginifica que o scanner est? com a trava ativada. verifica do seu lado esquerdo um trava amarela e destrave.
service manual with code for kyocera TASKalfa 180
paper crumpled
