Pull the spark plug and ground it to engine. pull rope, and you should be able to see a spark across the plug. If no spark, replace the coil. There really is no effective way to check a coil without a very expensive coil checker.
Pull the plug and connect it back to the ignition coil. Grab the plug in one hand and pull the starter cord. This is an effective way of checking if you are getting spark. You will know if its bad if you dont feel a slight pinch.??
