SOURCE: want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
SOURCE: ZEBRA printing issues via AS400
I fixed my issue and I now have my Bar Code?s printing via my AS400. I am now using just a straight outq as well. I converted my code to use the ?@? instead of ?^? as the control character, and I also had to tweak the settings in the remote outq, but here is my definition just in case you need to use it. If value not shown - default used Output queue . . . . . . . . . . > CARPR3 Name Library . . . . . . . . . . . > QUSRSYS Name, *CURLIB Order of files on queue . . . . *FIFO *FIFO, *JOBNBR Remote system . . . . . . . . . > *INTNETADR Remote printer queue . . . . . . > 'RAW' Writers to autostart . . . . . . *NONE 1-10, *NONE Queue for writer messages . . . QSYSOPR Name Library . . . . . . . . . . . *LIBL Name, *LIBL, *CURLIB Connection type . . . . . . . . > *IP *SNA, *IP, *USRDFN Destination type . . . . . . . . > *OTHER *OS400, *OS400V2, *PSF2... Host print transform . . . . . . *YES *YES, *NO Manufacturer type and model . . > *WSCSTCONT132 Workstation customizing object > QWPDEFAULT Name, *NONE Library . . . . . . . . . . . > QSYS Name, *LIBL, *CURLIB Image configuration . . . . . . *NONE *NONE, *IMGA01, *IMGA02... Internet address . . . . . . . . > '10.56.5.51' Destination options . . . . . . > 'XAIX' Print separator page . . . . . . *YES *YES, *NO Text 'description' . . . . . . . > 'Zebra Label Printer - Melbourne'
SOURCE: Eltron 2844 prints previous job over and over
Make sure the label size is correct, if the print encounters a gap before it is complete; it will re-print the same label. In MS Word make sure the page size is set to the correct size including any headers and footers and Width etc.
SOURCE: I cannot find a driver that will allow me to print
Try
www.seagullscientific.com and download the complete Zebra driver set
