EasyShare will not transfer the same pictures twice, so check to see if they are already in your EasyShare Collection. If you are unsure, take a new picture and connect again.
If EasyShare is running, there will be a little Kodak icon in your sys tray (lower right by default)...right click on it and choose transfer now, and you should see additional UI with options for transferring all or some, etc. to the Collection.
If your drivers are messed up for some reason, you could do a repair, or reinstall with the most recent version (6.4 at this point).
Let me know if these suggestions do not help.
Julie
Hi, Here are a couple things you can try to isolate the cause of this problem. Here goes: 1. See if the camera will connect and transfer properly on a different computer. If so, then the camera is fine. 2. Uninstall whatever software you are using to transfer pictures. If you have not installed any software, it is possible the OS is doing this for you. If you have WindowsXP or Vista, you do not need any software for basic transfer. If you are using the Kodak software that came with your camera, try uninstalling it and re-installing it. Hope these tips help.
