Aux input on the back depends if there was a aux button on the front and the brand of deck. If one is there then you dont need Best Buy to do it. removing the deck is not as hard as people make it seem. The best way to remove the deck to check is find a manual for removal; exp: chiltons, hayne or even get it from crutchfield. Be careful though, some decks may have the aux button and a 3.5mm jack in the back but the jack is sometimes used for a remote. So get the mauals for the deck you have and the manual for removal.
It would require a lot of time and investment on your end, I would recommend buying a newer deck with an aux input. The output from the cd player assembly is not the same as the output of your mp3 player. You would to do build a line level output converter and interface that to the preamp on the deck.
What you want to do won;t work and can damage your laptop and or Bose. If you want to play sounds from your laptop to your Bose, you need to plug an audio lead from the headphone socket on your laptop and connect the other end of this audio lead into the audio input on your Bose Sound Deck (if it has an Aux input).
well first off have you thought about getting a CD deck that has AUX input so you can hook up your MP3 to the deck by an AUX cable. as far as the tape player running slow i would say it needs to be cleaned by a professional because the little rubber belt may be going bad also. If you want to go to a AUX CD deck look at crutchfield.com or go to an authorized kenwood dealer in your area and look for the kenwood KDC-MP245. Going through the AUX instead of tape would sound a little bit better and if you want to go a bit better than the AUX then you should go to the KDC-HD545U. The KDC-MP245 is $99.99 before shipping and the KDC-HD545U is $169.99 before shipping. I hope I answered your question and please vote and leave high marks. Thank you very much.
You can go to radio shack and grab a 3.5mm to 3.5mm cable. make sure that is male -to - male. Some decks are equipped with an AUX IN in the front and some in the back and then some have both. This wire will resemble the same input end of an earphone plug. Once you have your device plugged in then just press the SRC button on your deck till it says AUX, AUX IN, or Audio. Let me know if this helps
what kind of cd player do you have? you must make sure that your unit has auxillary inputs. some decks dont have them. if it is set up with aux input rca's, then you just connect those to the mp3 player, then you should be able to play it in the aux mode on the deck. if you cant find it by hitting the source button, then you may not have it. I know on my sony stereo, I actually had to turn the deck off with the ignition switch on. then I press the menu button, and there I can toggle the aux mode on or off. if that doesnt work either, then you either dont have aux inputs, or the inputs are bad on the stereo, meaning its not gonna work at all.
I have a 2002 Pontiac Montana and I use a 2 pronged RCA plug at one end with a yellow plug and a white plug, and the other end is one plug to use for the MP3 player. Plug your RCA plugs into the bottom 2 plugs. My RCA plugs on my cord are yellow and black the yellow one is in the middle
plug and the black in the bottom one and I use the AUX input for my MP3 player. I have a SANSA
and a Ipod and they both work fine. I hope this helps. Just a FYI so you don't think your radio is
going whacko after you do get the MP3 player to work the AUX will always come on first and you will have to push the AM/FM button on the dash or the steering wheel to get the radio or DVD back on.
And the DVD player will have to be switched on for the AUX to play the MP3 player.
Have fun...
when something is plugged into the jack (mp3 player ect) there should work when you cycle through the options of the deck such as cd, radio, There should be an aux option when it is plugged in.
they are out jacks and you need to run the rcas to an amp and then run your speakers off the amp your mp3 player should work when you plug it in the front and press source aux unless the front jack is an out only
