Screen size 1. screen size to big 2.fonts to big 3.vertical to big Thank you
  • casey_philis Dec 02, 2008
    I have a emachine monitor and a dell tower and I cant read my emails the fonts are to big.
    Guru:
  • 859 Answers
Most Likely: Your screen resolution needs to be 1024x768.
Less Likely: You have an Appearance scheme such as Large Contrast.
Solution: Access Control Panel, select Display, then Settings tab and then move the slider to the above or higher resolution.
In the Theme or Appearance tab (depending on OS) choose a generic Theme or Color Scheme.
Regards,
Worldvet
Posted on May 21, 2008
Trying to set to higher resolution for windows vista onh190l
Posted on Dec 26, 2008
6ya staff
SOURCE:
My font size when messaging is too big. i need a solution for this.
Hello! Welcome to FixYa!
You can easily change the font size of
Samsung S3650 Corby Cellphone . Follow the given steps:-
1.Press menu 2.Select settings 3.Select display and light 4.Select font type 5.Select which you want from the given option and list 6.Save and exit.
I hope this solution helps you
Thank you for using FixYa
Aug 19, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Text to small
Change Your Font size.
1.Right Click on Desktop Click Properties "Display Properties will appear".
2.Click Appearance Change Font Size to Large Fonts or Extra Large Fonts.
3.Click Apply and Ok.
Or
Adjust Screen resolution.
1.Right Click on Desktop Click Properties.
2.Click Settings Adjust Screen resolution to 800 by 600 pixels
3.Apply and Ok.
Aug 13, 2011 | Computers & Internet
The font size of my messages has gone very small
1- Go to messages
2- Select message settings
3- Select font size option
4- Set the font size mentioned in the list for your need.
Jul 03, 2011 | Samsung Star GT-S5233 Cell Phone
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
To set the font size
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
I have a 55 in Sony Grand Wega LCD TV that has some strange lines that look like cobwebs. They seem to be floating behind screen. What could it be? The TV is 6 years old
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} CAUTION: immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
A single horizontal line means that you have lost vertical deflection. High voltage is most likely fine since there is something on the screen.
This could be due to:
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels.
may be a jumper plug or other means of selecting service mode - not an actual switch.
When moved to the 'service' position, it kills vertical deflection and video to the Tube. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection ports or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection ports on the Tubes.
Bad vertical deflection IC or transistor. You will probably need the service manual for this and the following. However, if the vertical deflection is done with an IC, the ECG Semiconductor Master Substitution guide may have its pinout which may be enough to test it with a scope.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals.
The most likely possibilities are in the deflection output stage or bad connections to the yoke.
Computers & Internet Logo
877 people viewed this question
Ekse
Marvin
Marvin
