Schumacher 400w Power Inverter Logo
Posted on Sep 23, 2010
I have the SSC-1500A battery charger and the yellow light keeps flashing. The yellow light is the charging light.not sure why
H Jorgy
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 30, 2014
H Jorgy
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1096
Points
This unit will assume a battery voltage less than 1.5 volts means the battery is sulfated. The flashing yellow light means it has gone into 'desulfate' pulse mode using pulses of high voltage to try and convert the lead sulfate back into sulfuric acid and lead plating. It will do this for about 8 hours on the charger I have. If the voltage has not raised to a level that can can accept a normal charge it will abort the pulse mode and stop trying to charge it. You will need to unplug and replug in the charger to try again. Always check the temperature of the battery while charging it and especially if the charger is in pulse mode. Stop charging if the battery is hot. *always wear safety gear*
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Pronto power chair why does the lights reds yellow and green keep flashing and when I hooked up the charger says full charge any answers
Sounds like either the battery or the charger is not functioning correctly. Battery may need replaced, or charger may need fixed or replaced.
1helpful
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
2helpful
Yellow and green light are on but wont charge battery?
If both lights are on and both are flashing the charger is reading the battery as defective and the charger won't charge the battery. If the Red light (yellow if plastic is faded) is on and the green is flashing the charger is trying to charge the battery. If the battery won't charge replace it.
2helpful
Problem charging
If you are referring to a flashing yellow light on the charging base, this is an error code. Either the 1) battery is bad, 2) not making good contact in the charger, or 3) very very low on charge. The solution for this set of problems is as follows: 1) have the company you purchased them from replace them, 2) clean your contacts with a pencil eraser, 3) leave the battery on the charger with the yellow light flashing for an hour or two. If the battery is just very low on a charge, it will come back to life and the light will change to be constant. If the battery is bad or shorted out, the light will continue to flash and you will need to get with the vendor you purchased the batteries from.
Other things which come to mind are compatibility issues such as you are using a different battery chemistry than you had before. NiCd batteries can charge on either of the two chargers available for the P110 (slow rate or fast rate). However, NiMH and Li-Ion batteries require a fast rate charger.
If you are referring to a yellow blinking light on the radio while it is in the charger. You need to shut your radio off. Radios should always be turned off when charging. If the radio is left on you will never have a full charge. Also, if you inadvertently press the PTT while the radio is turned on, while on a charger, you can cause damage to the radio.
FYI: There is no light to show "out of range" on the radio, unless you are possibly using a trunking or repeater system. A blinking light on your radio indicates the radio is turned on and/or there is traffic on your frequency. Your charger base light can be red, yellow or green. This indicates the charge cycle status. Flashing most always means some type of error.
Best regards
When i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
Top Schumacher Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Schumacher Electronics - Other Expert? Answer questions, earn points and help others
