Riverdeep American Greetings Create a Card 7 Gold for PC Logo
Posted on Feb 14, 2018
I have purchased a new PC which operates on 64 bits. my older "Creatacard" Will not load. Future Shop, Best Buy, Staples & London Drugs deo not have a new version to operate on 64 bits. I realy miss 'forget-me-not as an address book. John A. White, 604 531 7906 or [email protected]
I run win7Pro & AG CreataCard Platinum 8 will not install..is my favorite card making program for family & friends, any help appreciated.
CreataCard Platinum 8 was written for XP and older versions of Windows. Changes in the OS make it difficult/impossible to install.
Do you have the 32-bit or the 64-bit version of Win7Pro? Click Start > Control Panel > System and Security > System. If the title reads Windows 7 Professional x64, it's the 64-bit version. (If it doesn't end with the x64, you have the 32-bit version.)
In any case, the best option is to try running an older version of Windows on another machine, a dual boot system or a virtual computer. With the Pro version of Win7, you can run a virtual XP for free (if your hardware can support it). Download and install Virtual PC and the XP mode package from Microsoft. (You'll need to set aside some memory for the virtual PC to run.) Then install CreataCard when running XP mode as if this is your only computer.
The only real problem is that you will not be able to have hardware installed on the virtual XP and the Windows 7 real machine at the same time. (So you can't share a printer.) Also, to share files between the two "systems", you will need to save them to external media (flash drive or optical disc, for example). Your motherboard and CPU need to support Virtualization. You have to turn this on in your BIOS on some systems. (Press Esc, F1, F2 or F10 repeatedly depending on your system right after turning on the system. If you miss the timing, shut down the computer and then retry.)
Other virtualization programs are Parallels and VMWare. However, with those programs and the other possible options for running CreataCard, you need a licensed version of the older version of Windows.
If you have the 32-bit version of Windows, you can try the Compatibility Mode. (Right click on the installer and choose Properties. Then click on the Compatibility tab and select Run the program as compatible with an older version of Windows. Apply the changes and click OK. Then right click on the installer again and choose Run As Administrator.) You may have to repeat this on the program icon after installing. However, the compatibility mode doesn't always work even if you have the 32-bit OS (and thus don't need the signed driver).
An alternative is to upgrade your software to one that is Win7 compatible. I'm not sure which of these Broderbund design and print products are most similar to CreataCard: http://www.broderbund.com/c-6-design-print.aspx . However, you will probably not be able to open old documents.
I hope this helps.
(XP mode is available with Win7Pro and Ultimate. At my house, we have two computers with Win7Pro with one running XP mode. At least once, the virtualization was turned off during a BIOS update and XP mode failed until the setting was corrected.)
2answers
I have changed my computer to Windows 7 Home premium with 64 bit operating system. I have creatacard 3 and have tried installing it on my system. however it is not compatible with this system , how can i...
Start the "Windows Compatibility Wizard", and tell it that you want to install a "Windows XP" program. Windows 7 will then read the CD, and install the program, and run it in "XP" mode.
2helpful
2answers
I can't download ms office 2007 full version how i can do it???? please tell me
:) This is not the right place for posting such kind of questions. Better try to google it :)
2answers
Where can i get replacement vga cable for Princeton vl 1715
> where?
Almost anywhere -- WalMart, Best Buy, Future Shop, Office Depot, Staples, London Drugs,
or online via 'www.ebay.com' or 'www.ncix.com' or ....
I had an application called "creatacard gold 3" on my old computer with xp. I have all my important information from past 10 years is on that application. the computer crashed and i needed to buy a new...
The CreateACard Gold 3 (CAC Gold 3) will never work with Windows 7 64bit unassumingly because the software producing company has not upgraded their software for even Vista 64bit.
I recommend you to switch to " Hallmark Card Studio Special Edition" it has all the features of CAC Gold 3. You will enjoy it as there should be no problem installing it with Windows 7 64bit.
Good Luck!
Old CreataCard Version
I have an older version of creatacard and want to install on Windows 7. Have 64 bit.
1helpful
2answers
I just bought a new computer that has Windows 7. I try to download my Creatacard Gold3 and am told it is not compatable with a 64 bit driver. Do I throw it out or is there another way to install it?
Two options. Try Googling. Maybe the Creatacard software provider has a 64 bit version of the program available as an upgrade. Many Vista 64 bit programs work OK with Win7.
If this doesn't work and you REALLY need to use THIS program, you can install a 32 bit version of another operating system as a dual-boot. Either XP or Win7 would work. Or run a 32 bit operating system on a virtual machine and run the program on the virtual. That's rather high tech just to run a card maker. So if they don't have a 64 bit version of the program, look for another supplier who does.
64 bit provides faster operations, but it does render a lot of older programs unworkable.
Top Riverdeep Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Riverdeep Computer and Internet Expert? Answer questions, earn points and help others
