SOURCE: My bosch washing machine wfo2865
remove back panel.remove motor wiring undo two bolts in front. remove belt. motor will pull out.
my experience of these is that often the commutator is damaged hence brushes worn
SOURCE: bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
SOURCE: WHERE ARE THE BRUSHES FOR BOSCH EXCEL 1400 EXPRESS
Some of the motors Need A HALF motor which is the end section with brushes fitted, quite expesive if you can get brushes they are around 5 times cheaper if you check a parts website that will tell you which one u need...
SOURCE: washer will not do Final spin. the time stays on
If the clothes are extracted of water it very well mean your timer needs adjusted slightly, If not, timer needs replaced. Remember, not 100% of your rinse water will be extracted so don't expect it to be hand touch dry when you remove load.But it should not be dripping wet or soaked either
SOURCE: bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
