Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Not all of them at once. Only one. The hot key varies from model to model. There will be a brief message on the first screen you see when the computer is starting up telling you which button to push for "system setup". If unsure boot the computer and watch closely and note the button to push. Then hold down the power button until the computer restarts and be ready to hit that hot key.
Choose to enter BIOS setup.
Use the arrow keys to select the BOOT tab.
Find your preferred, always boot to first disk, and give it priority,,,( move it to the first position in the list) and then hit F10 save and continue. Your computer should reboot to the drive you selected.
SOURCE: samsung cd-rw drive sh-r522 problem
IF THE DRIVE SHOWS IT ,, then its hardware
eighter the drive is defective or something is wrong with the MB/P
try the drive on a different computer if it works change your mother board format and reinstall
if it didnt work take it back for warrenty or get a new drive
SOURCE: problem with samsung x 05 cd rom
It sounds broken but as a last ditch effort I would try disabling it in device manager and reenabling it.
SOURCE: CD ROM drive not seen in "device manager"
i think you are going to have to boot into bios and where it shows the boot configuration look to see if there is a cdrom there if not change it so the computer will have the cd rom in there along with the harddrive and the a drive then save it and exit and reboot then the cd rom should be back into the device manager and also under my computer
SOURCE: How to copy files from my PC to my SAMSUNG i900 and vice versa
With PDA phones you need to use a program called ActiveSync,
it is a free program. Once you have that install, you will be able to put files to the computer and the phone.
SOURCE: windowz format problem????
check you system setup if the hard drive is detected.
if detected:
when start up. select the boot menu (some laptop press F12)
select optical drive (cd/dvd)
when installing the new windows.
when ask which drive are going to install windows
delete and create new partition for your hard drive
then format (dnt do the quick format)..
I believe you'll have to copy content to a hard drive that can be installed in the laptop. I didn't understand your problem at first but I have tried what your talking about and the way it worked was taking the old drive out of the laptop and copy all contents to that drive from a pic or orthe computer then reinstall the drive in the laptop. The computer should take over and finish the install as normal. Let me know if this helps.
