Question edited for all the typos.
Question moved from Photography to Panasonic Fax.
It took me a long time to work this one out.
'make model (what it is)' in all questions please. It is referring to 'Fax Film Ribbon'. Video at the bottom. And what is _probably_ your manual?
https://www.youtube.com > watch
PREVIEW
1:27
How to replace the Panasonic Ink Film (Thermal transfer ribbon TTR) for use in Panasonic KX-FA52X for ...
YouTube · viandant5 · Mar 14, 2017
9 key moments in this video
https://www.youtube.com > watchPREVIEW1:27 How to replace the Panasonic Ink Film (Thermal transfer ribbon TTR) for use in Panasonic KX-FA52X for ...
Yes you can fix.
please go to repair personal with power adapter or buy same type one or by alternative power adapter but output must be same as the original and 220v as in .i think buying new one is a good idea.
1. Open the top cover. 2. Pull the lever towards you to release the daisy wheel lock. 3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear' on the top right. 4. Insert the desired cassette daisy wheel into the slot and press down gently. 5. Slide the lever back to its' original position to lock the cassette daisy wheel in place. Make sure to press the lever firmly. 6. Close the top cover. 7. Press [CODE]+[RESET] to move the carrier to the previous position. (make sure the daisy wheel cassette is not inserted backwards. The "ear" should always be on the upper right. improper insertion of the daisy wheel may cause malfunction and incorrect printing. It is not necessary to remove the cassette ribbon when replacing the daisy wheel. Please check the shape of your daisy wheel cassette before replacing the daisy wheel. The daisy wheel cassette type "B" cannot be used with this machine.)
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes
position. According to Brother, if this is not done the typewriter will print incorrect characters.
Try these steps:
1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove
the Daisy Wheel by pulling it up and out.
2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey
Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel.
3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward.
4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as
is printed on the Daisy Wheel.
5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter
mechanism and align (or time, in technical terms) the carriage mechanism.
Check if the typewriter prints correctly now. If still incorrect, perform these additional steps.
6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the
I=Standard position. The other positions are: II=International and III=Symbol.
7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the
switch contacts in case they are dirty and not making good electrical contact.
8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism.
If still incorrect, the only other things I can think of is that:
1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with
two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.)
The B type are incompatible with your machine.
2) the typewriter has failed and needs repair.
