SOURCE: Rapidly blinking green sleep timer light, cannot
The Chassis will need to be sent to Mitsubishi to be refurbished. I would call Mitsubishi at 1800-332-2119 to see if they would help in the repair cost and also to refer a Service Facility local to you to do the work. I would estimate the cost of about 300.00 to 400.00 if Mitsubishi helps with the cost. If they don't, I would estimate the cost to be around 700.00 to 800.00.
I hope this helps,
skyassoc
SOURCE: green timer light blinking rapidly after power
The chassi will need to be removed and sent to Mitsubishi to have it rebuilt.
SOURCE: Blinking Timer light on Mitsubishi WD62725
get a ohm meter and check all fuses ,and diodes they should all read 0. the ones do read something are bad replace them that means solder them out and back in
SOURCE: The green timer light blinks rapidly when the set is turned on
Unfortunately in this V-26 chassis TV whole sandwich of 5 PCB has to be rebuild by Mitsubishi to solve this problem. If you out of warranty - don't bother to invest any more money or effort. It would be at least $700+ repair.
