SOURCE: sound card problem for intel desktop board D101GGC
SkullyFox give the good solution but let me tell you one thing.....
If you by mistake installed the wrong drivers in the Realtek chipset sound then you have to remove or uninstalled the sound application …..
Intel Original all the boards having the same problem ….
Over the internet one patch is available for Realtek sound drivers first you need to install that patch after this also sound not came then try re-installing the Sound application…
SOURCE: were can i download realtek ALC888 audio codec
another site
microsoft.com/driverdownloads
was the driver working before
SOURCE: Realtek audio driver 5.10.0.5423 installation problem on my pc
Hi There,
Go to the Intel website, ...
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2766&lang=eng
Select your operating system, and download the audio driver for your device.
Before you install it, restart your pc ,Log into the Bios, make sure that your onboards audio is enabled might say onboard AC97.....
Then go and install you driver for the device, Hope that helped you, IOf not let me know
Regards
techmor
SOURCE: realtek audio driver of intel 845gl/gv
Realtek Ac 97 audio driver of intel 845gl/gvDOWNLOAD HERE
SOURCE: i had installed realtek audio driver but is shows no audio driver
Download the driver here at intel:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
Please remove the old one before you install the new.
Good luck
