I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things...
Bought new spray arms online and installed them inminutes...now the thing works like new...
However I have also found that if the heating element goesbad then that also can mess things up bad...
So I would buy new spray arms, and also check out theheating element to make sure it is working...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems indishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
