HP Compaq Presario SR1720NX (EL435AA) PC Desktop Logo
Posted on Sep 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Win 98 recovery used instead of win xp sp2. computer won't start, shows win 98 screen and stops
brismac
Level 2:
New Friend:
  • Expert 93 Answers
  • Posted on Sep 22, 2010
brismac
Expert
Level 2:
New Friend:
Answers
93
Questions
0
Helped
42731
Points
247
Win XP will not use anything from a win98 program. If XP is installed you must either use the recovery discs or better, the original XP disc.
1helpful
2answers
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Tried inserting recovery cd-rom in satellite P10 (windows XPHome) and first screen shows message about running Windows98! Aborted process and PC is OK. Is it safe to proceed?
should be. It looks like someone updated that computer from Win 98 to XP - that's why the recovery disks are for Win 98. You should be ok to proceed if you didn't do any of the recovery. Are you able to use System Restore to force computer to revert to an earlier time when everything was working ok?
How to fix ntdlr is missing?
substitute the NTLDR file in the right place. if you have access to another computer, copy the NTLDR and NTDETECT.COM which is available from the recovery CD which comes with computer. If you do not have the recovery CD, they were available from another computer using the same Operating System (Windows XP in your case). The location was C:\i386\ntldr C:\i386\ntdetect.com then use a bootable disc to restart the computer (the Win XP bootable CD may not work, a Win 98 bootable CD will work). After entering MS DOS mode, copy these 2 files to the C drive in the proper location. After restart, then pressing F10 on start up (used for system recovery on my computer), start the repair of Windows via system recovery (which was not possible earlier). This reinstalled all Windows drivers and system files, while preserving all data on my computer.
2helpful
Cannot install in win XP
dear frn, that is the problem of win XP sp3, so better to use the winxp sp2 and better to update it. instead of using sp3 ok
1helpful
Xp recovery
You need to download all the drivers installer files from manufacturer website first, and also all the software you want to install automatically with Windows. Then you build a Windows Xp boot CD with all the software setup embedded.
See the links below:
Build an XP-SP2 Recovery Disc - Solutions by PC Magazine
Geek Repair: Create Your Own Ultimate Recovery CD :
Bart's way to create bootable CD-Roms
Slipstream a Windows XP SP2 Recovery CD
Build your own XP SP3 Recovery Disk -
Build an XP SP3 Recovery Disc
Dual boot problem
first install win98(dont re boot for xp installtion),  while running 98, insert cd of xp and install xp from there.
1helpful
Driver
If you are talking about the Agfa ePhoto CL18 Digital Camera, then you'll need drivers for the digital camera, not webcam drivers, but in a way, I use mine as a webcam sometimes, but using the drivers will only work for WIN95/98/98ME/98SE/WIN-XP etc. and the drivers won't work for WIN-Vista as Agfa discontinued supporting digital cameras and flatbed scanners, so I actually made Recovery disks for my WIN-Vista, so I could put that back unto this computer, which came with WIN-Vista, and used my WIN-XP disks and installed WIN-XP unto the computer just so I could use the WIN-XP driver. When installing the driver there's an error message telling me that it can't update DCOM, or DCOM95, or it can't update DCOM to WIN98, or some sort of error message, but I just rebooted the computer and the install completed. Sometimes however, the computer "loses track" of the driver or something because sometimes, when I start the Corel Photo House software, which came with the camera, there's a message telling me that it can't find the camera and that I should make sure that the camera is connected and turned on for example, but I found that if I go into the "add hardware" section again, then try the automatic install again, but instead of letting "it" find the driver, I tell the installer to choose how or where to look, the driver that was installed will show up on a list, then after I click on that choice, then it installs correctly...In other words, the driver installs correctly after installing it the first time, with the CD, then installing it a second time using the computer's "list" of drivers, if you know what I mean by that...It's where you click on where you choose what hardware you want to install and get the list of available drivers, if you know where I'm talking about?
Good luck in getting it going.
Read: http://www.agfa.com/en/co/support/scanners/index.jsp
manual, software or driver for your scanner or digital camera: http://static.agfa.com/digicam_scanner_drivers/
Drivers ePhoto CL 18 (USB) Windows (95 OSR2, 98, ME, 2000, XP): http://static.agfa.com/digicam_scanner_drivers/digital_camera/ephoto/cl18/index.html
Have a Great Day, Bernard
My hard drive shows only 1.5 GB instead of 100
is it correct that you installed XP from an "upgrade" pack?
when you installed XP did you convert the file system to NTFS?
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
