SOURCE: connection problem on my router
router is configured incorrectly. I need more info to help you. who is your DSL thru? is it using PPOE (probably)? are you having trouble thru wireless or wired into router? suggestion...call your DSL provider they should be able to help you ge tthis configured over the phone. If not...let me know...we can work on it.
SOURCE: Westell 6110, No internet light.
Contact verizon if they can replace the router becase the internet light should be green and flashing as you use the internet.
SOURCE: Modem Light Flashing, Internet Light Off, No Internet Connection
Hi, Here is your solution.
Please ensure the proper physical connection from modem to router and to the computer as mentioned on the box and make your all lights are on modem.After that turn on the router,if your have a cable modem, you can very well go for a hard reset,that it is at the back of your router you would see a reset button which is a button inside a hole. Please hold the button for 20 secs with power on router and 20 seconds without power continuously for 3mins (remember to hold the reset button through out 3 mins while plugin and plugout the power cord of the router and use pin or pen to hold the button). After this check out the lights on your router, lan light, internet ,power and modem should be solid.Else you can call the customer service number on the product box, they will assit you very well,ITS A TOLL FREE NUMBER.
SOURCE: DSL link is not stable and unable to establish broad band connection.
I had similar issues with my Linksys WAG200G WiFi ADSL modem/router. I tried with hard reset and reconfiguration and even upgraded the firmware. However things did not work.
I stay at Vasai, Dist: Thane, Maharashtra, IN.
I one day observed that when there is no electricity (as there are schedule power cuts in my region) and while my Linksys router is on the (sine wave) inverter power. The link is stable and the ADSL fluctuation (rather frequent fluctuation/disconnection) starts when the mains power comes back. I observed this situation for couple of days and then tried and switched off the mains once when my router was giving issue and Bingo.. the ADSL connected instantly and was stable again. This could possibly be due to the voltage fluctuations with the mains MSEB power supply.
Conclusion: The power fluctuation tolerance with Linksys is not that good as compared to some Indian made ADSL modems. I am planning to install a small UPS for my Linksys router as a permanent solution.
Regards. Jordan Dias
