SOURCE: The drain pump on the AEG oko favorit 6050 keeps
This can only be the controller.
Only the controller (timer) turns the pump on and off.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Testimonial: "very quick, thankyou"
SOURCE: Error code C2 showing on my Oko Favorit
Error Code C2 means drain line totally blocked.
Check drain valve for restriction in pump, check drain line. When there is no problem in drain line then check for a bad float switch or a bad control board . You will get this error even when there is no water in the tub . You can check the float switch with an ohmmeter. It should be open if the float is up and closed with the float down.
Hope this helps .
Thanks for using FIxya.
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
SOURCE: AEG OKO-FAVORIT 50800
C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
If this happens often you have a leak somewhere. Time to cal the technician then.
