Question about Life Fitness 95Ti Treadmill 95 Ti
Why does my lifefitness series t screen read immobilized?
I believe the tread has been locked out (safety feature important for clubs) - you can call lifefitness and they will give you the key sequence to unlock it
Posted on Nov 05, 2010
6ya staff
SOURCE:
How do i find the problem with an electrical fault on the daf cf75 series. Truck wont start, it is cranking.
run the fault codes read
non starting can be related to the following components :-
ignition (engine) immobilizer
cam shaft position sensor
crankshaft position sensor
oil pressure sensor
Sep 12, 2015 | DAF Cars & Trucks
Tip
95Xi Crosstrainer Pedal Replacement
Video about How to Replace the Pedal on a 95Xi Crosstrainer by LifeFitness
  • This video is about how to replace the pedal on a 95Xi LifeFitness crosstrainer
  • Tools necessary:
    • T40 Torx Driver
  • Remove the (4) torx bolts securing the pedal to the pedal lever assembly
  • Install the new pedal in reverse order
  • This completes the replacement of a pedal on the LifeFitness 95Xi
Life Fitness Crosstrainer 95Xi Video Pedal Replacement
on Apr 28, 2014 | Exercise & Fitness
Treadmiill keeps saying waxer needs filled after filling it
please see the cause and remedy and fix it. Please read carefully your section of troubleshooting instr. manual or download
Inspect spray pattern between 8" (200mm) and
16" (400mm).
If not, verify wax nozzle is clean, hoses are not
kinked, wax bag is not empty, or wax is
contaminated.
http://www.sportsmith.net/images/product_support/lifefitness/Treadmills/TR9100/9100 Treadmill Manuals/Service/m05100k
God bless you
Nov 29, 2012 | Treadmill Doctor LifeFitness 9100...
I have problems with my dodge grand caravan 2005 won,t start an show this code p0513
P0513 - Incorrect Immobilizer Code
Possible causes- Open or short immobilizer circuit
- Poor electrical connection for immobilizer circuit components
- Faulty immobilizer control unit
- Faulty immobilizer key
- Faulty immobilizer key antenna
Read more: http://engine-codes.com/p0513.html#ixzz24sUqroQI
Aug 28, 2012 | 2005 Dodge Caravan
The screen reads "Unit immobalized
Here is the manual for your unit. See the section on Managers Configuration specifically custom message on page 37.
http://jp.commercial.lifefitness.com/resources/content/4/9/7/3/documents/95Te%20Console%20User%20Manual.pdf
May 16, 2011 | Life Fitness 95Te Treadmill
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Feb 02, 2011 | Life Fitness Exercise & Fitness
The screen reads "unit immobilized
To Get to the manager and check for disabled items.
To enter the Systems Options Menu:
1. Press SELECT WORKOUT.
2. Touch the Life Fitness logo in the upper right hand corner of the screen three consecutive times
go to configuration
Configuration
Allows authorized personnel to access all configurable settings of the unit. Configurations which should only be changed by qualified technicians are password protected.
Manager Vivo/Network
Manufacturer , Create Your Own
Media Center , Clock
Custom Workouts
Touch Screen Configuration
Export / Import Settings
The console manual will show you all the default values .
https://www.lftechsupport.com/c/document_library/get_file?p_l_id=27605&folderId=483177&name=DLFE-28306.pdf
Feb 01, 2011 | Life Fitness 95Te Treadmill
Heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Mar 12, 2009 | Life Fitness 9500HR Next Generation...
Treadmill has automatic shut off sensor when i walk on it for a time
Sounds like the sensor that detects someone is on it is bad, Here is the service manual that should help.
LifeFitness 9500 Series Service Manual
Nov 02, 2017 | Electronics - Others
Life Fitness 95Ti Treadmill 95 Ti Logo
411 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Android Man
Android Man
Kenneth Simmons
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
