SOURCE: olympus sp 350
Are you sure you finalized the firmware upgrade procedure according to the instructions? This sounds a little like you pulled the plug a little too soon... Have you done it according to these instructions: http://www.olympusamerica.com/cpg_section/OMfirm.asp And kept the camera connected until the update was 100 % complete? If you did everything right, try reseting the camera - take the batteries out for the day, and see if it helps. if you're back to step one(the reason you did the upgrade), try the firmware upgrade again. If still it doesn't work contact olympus, and I hope you have a valid warranty. Good luck
SOURCE: Olympus FE-115 : wont turn on..turns iself off!!!
I had the same problem and i called up cutomer support on 1300 659 678 (Australia) and they said that the problem may lie in your batteries. It was advised that you use Lithium batteries, and to avoid use of Alkaline, since they dont have the required power to operate the camera which is why it turns off right away. As to what type of rechageable batterires to use i am not sure, i think it was Nickel-metal-hydride (NiMH) batteries. Hope this solves your problem.
SOURCE: camera batteries drain quickly
Open the battery door and check the contact between the camera and the batteries. Most often then not there is just a bad contact and it's ruinning your baterry life.
Make sure that the contact are well placed and that there is no rust or dirt build up around there.
SOURCE: my camera says write protect and won't let me take pics
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
SOURCE: my camera keeps turning off when i try to take a picture even whe
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
