If there is something wrong with the printer, you should get a error message describing the error.
Does the printer have a blinking orange light after you give the print command? Then there is an error in the printer. If you have documents in the print queue, delete them. Remove the printer cable. Shut the printer down, shut the computer down. Reconnect the cable and turn everything on again.
If there is still a problem there might be something wrong with your printer.
If you don't have a blinking light after the print command on the printer, then try changing the printer cable. If not working, try another USB port. If still not working, reinstall the printer.
