Texas Instru... Master
- Posted on Sep 21, 2010
Re: Batteries good, but can't enter numbers.
If you cannot enter numbers that means memory is full or command line is full. You must make room for new commands and new data.
I suggest to
Reset the memory or clear the data, equations, graphs etc. that may still be in calculator memory.
TO RESET THE RAM (any programs you typed in) will be deleted
- Press [2nd] [ ] to open Memory management tool
- Press 7 number key to select [7:Reset]
- You will be asked to select [1:All RAM] or [2:Defaults]
- Select [1:All RAM]
- Press [2] to Reset.
- After memory is reset calculator displays Done.
To delete items selectively.
- Select [2: Mem Mgmt/Del..]
- If you know what kind of objects you want to erase then select any other appropriate item but [1:All]
- If you do not know what is taking up space select [1:All]
- A lising of all objects in memory is displayed
- When thery are empty, the Lists L1 to L6 are 12 bytes long. Letters are 18 bytes long.
- To delete an iten in the displayed screen, highlight it (by moving cursor to its level) and pressing the [DEL] button.
Go then through all the listing and delete variables, prograns, objects (graphs) that you want.
After you finish, press [2nd][MODE] to quit.
Allow the calculator some time to defragment the mempry.
