Panasonic KX-T7730 Corded Phone Logo
Posted on Sep 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you change the display name of the person you are transferring to?
Carl Navarro
Level 3:
  • Panasonic Master 2,460 Answers
  • Posted on Sep 21, 2010
Carl Navarro
Panasonic Master
Level 3:
Answers
2460
Questions
Helped
1155375
Points
7314
It depends on the system the phone is connected to. In a TA series (most likely) it's programmed either from the maintenance console software, or a phone connected to system programming via Jack 1 program 604.
Your Programming Manual for the particular system will have complete instructins on accessing and programming extension names.
Carl
2answers
Hi I have a Nec DT300 at work. I am on a new desk. Do you know how I can change the name which is on the display.
If you have the Admin password then follow this procedure:
For a DT330 (24-Button with 4 line LCD)
Do not lift the handset and press the Speaker button
Enter #*#*
Enter the 4 digit admin password and press the Transfer button
The phone will now display 'Program Mode'
Select Base from the four options using the associated softkey
Enter 15 and press the select softkey 2 times
The Extension Number and Ext Name will be displayed
Find the Extension Number you want to change the Extension Name for using the + and - softkeys
Press the Mic button to go to the Ext Name line
Enter the New Name using the number dial keypad.
If you make an error the Recall button will delete a character to the left and the Hold button will delete all characters to the right of the cursor.
Press the Transfer button to accept the new name.
Press the Answer button 4 times or until 'Program Mode' is displayed.
Press the Speaker button.
The system will save the changes and return the display to normal.
2helpful
The voicemail and display (internal and external), have all been changed for a new employee. She has recorded a greeting, however, whenever a call is transferred to her internally the recorded name - that...
The recording you need to change is the "name in the company directory".Thats done by entering thier mailbox pressing the admin soft key then pressing the number 1, saying both thier first and last name and pressing ok.
How do you change the main display name on a Panasonic KX-T7453?
hello,
enter the menu of your phone, go to profile choose the profile you want and personalize it.
when personalizing change the name of the profile to the you want and activate the profile.
i am sure it will display your name.
thanks for using our website.
Panasonic KX-T7668 Change name displayed on extension??
This facility of changing name is in admin program. when you call up some body their name will bw displayed on your screen. It's fine .tell us that what name other person get.
1helpful
2answers
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
How do I change the persons name that is programmed on the phone already?
go to administrator phone
usually are receptionis phone
press MODE button
press ADMIN
key in pasword "0000"
display show phone name
press HOLD to skip
display show DN ID
DN stand for extn number
key in extn number
the exiting name will shown...use scrool n page for backward n forward the cursor
key in the person name
press hold to confirm
to exit press MODE button untill time n date r displayed
50helpful
Samsung iDCS 18D Office Phone
Hi, You can change the name on your Samsung phone by hanging up the phone then hitting the 'transfer' button then the numbers 104. Now use the numbers on the keypad to enter your name like you would on a mobile phone for SMS. Hit 'transfer' when youre done and your name should be set.
bye
-Mark
www.digitalinsite.net
1helpful
NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
  1. Press the Speaker key (do not use the handset).
  2. Dial the Name Assignment access code and wait for the special dial tone.
  3. Using the key pad spell the name. Press each number until the letter appears.
  4. When the correct letter is displayed Press the HOLD key. Pressing the HOLD key will lock the letter in place and advance to the next position.
  5. Repeat steps 3 and 4 continue to spell the name.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
3answers
ME AGAIN
From extension 201: Press transfer then dial 104. Press the up arrow until the station number and name you wish to change is displayed. Press the hold key to delete the current data and enter the new name with the keypad by pressing the digit 2 one time for A, press the digit 2 two times for B and so forth. The volume up and down buttons will move the cursor left and right. Press the transfer key to store the new data.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
