The code list gives these codes for Sharp TVs: Sharp 005, 021, 071, 085, 087, 092, 128, 183, 208, 274, 298 .
Press PGM and then enter a 3 digit code followed by OK. The indicator light should have come on when you pressed the first button and go off after you enter the code. Try to change the volume on the TV. If it doesn't work, try another code. If the indicator light blinks 4 times and then remains lit, you may have entered the wrong code. Try again.
If you still have a working remote for the TV, it will still control the TV (just make sure not to change the TV channel).
I hope this helps.
SOURCE: i need the code for my sharp tv so i can program my rca remote co
After much searching I finally found the code list for RCR451 Universal Remote. Here are the codes for Sharp TV. 1004, 1007, 1009, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1195
SOURCE: I need codes for a rca DTA800B1 converter box so I
Hello Mitzisexton8
Here are the codes for Quasar 012,038,092
Hope this helps you out.
Cheers Little Dish Fitter
SOURCE: Need remote programming codes for RCA Digital Converter DTA800B1
Use the SKU number of the RCA remote to look for the code here. Click on "Find your Remote Codes Here" at the left side of the screen.
SOURCE: Need codes to program the
Please find info from the links below; remote control codes: http://www.espares.co.uk/search/remote-controls/p/1090?utm_campaign=06-2011+unlimited+credit+1st&utm_medium=email&utm_source=emails ........ search for models of all types http://www.xdiv.com/remotes/
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
SOURCE: We have also lost the
Press PGM on the remote control. The signal indicator on it remains lit.Enter the 3-digit program code with the number keys. Press OK The signal indicator will be o when the program is one.Press the volume keys on this remote control to check if they can adjust the volume of your TV set.• If you fail to control your TV set,repeat steps 2 to 4 to program again. Try another program code if there is more than one for your TV brand.• If the signal indicator remains lit after blinking four times, you may have
entered the wrong code. Repeat steps 3 to 4 to program again. Make sure you have correctly entered the code.• You can still use your TV remote control to turn on your TV set, select input source and control the volume.for conrmation.your sharp tv code is 005, 021, 071, 085, 087, 092, 128, 183, 208, 274, 298
