SOURCE: LOW WATER CUTOFF IS CHATTERING ON WEIL MCLAIN
Don't jumper that control out. You likely have some thing going on with the make up water. best i can do with information provided. T
SOURCE: Weil McLain boiler for baseboard heating at home.
Hi is there a flame sensor on it , sounds like in needs cleaning along with the pilot light try this it might help
SOURCE: How tough is it to install a new tankless coil in
There will be a screw or nut that holds the whole control in place. The probe is very short. When changing the coil, make sure you have a clean surface on the boiler where the new gasket will mate. You can use some high temperature silicon to hold the gasket in place but just use a minimal amount. Too much and as you tighten the bolts, it will push out the new gasket. Before attempting to loosen the bolts, spray them with penetrating oil a day prior to the repair. An impact wrench will quickly loosen the bolts if you can use one.
