The unit is working and all the speaker do work, but the volume is so low on the surround sound speakers that it's hard to tell tey are on. How do I adjust the volume on those speakers. The directions say to go through a series of commands, but they don't work on the unit.
1. put a dvd into the drive
2. stop playing it.
3. press and hold channel select button [ch select]
4. this will show different channels....scroll through them and using he four arrow keys increase or decrease the volume...
should wrk....
Hi Jessie-
I found this link to the Panasonic DVD Home Theater Sound System SC-HT995/SC-HT995W. The Panasonic wireless system SE-FX61 works with the HT995W only. On pages 9-11 of the manual, it shows how to connect your surround speakers to the wireless SF-X61 unit in order for it to work. The SF-X61 unit sits between the rear R and L surround speakers (as illustrated on page 9 of the manual). https://panasonic.ca/viewing/ALL/SC-HT995/OI/rqt8766-1l/rqt8766-1l.pdf
If none of your speakers gives any sound, perhaps you pressed the mute button on the remote control?
Make sure you have a source selected, that will give sound. Choose a low volume, before switching anything. You can destroy your speakers, when switching on with full volume.
If some speakers work, and only the surround does not work. check if you have surround sound as input. If you only feed 2 channels you can't expect to hear more than 2 channels.
Verify that all cables are plugged in correctly. Make sure the rear
and/or center/sub audio cable is plugged in to the correct port. On
most surround sound cards, the rear audio port is black, the front
audio port is green, and the center/sub audio port is orange. If you do
not have a surround sound card, make sure you obtain the proper adapter
(discussed in the next paragraph) or use surround sound emulation if
your speaker system offers it. If you are not sure if you have a
surround sound card, please check with the manufacturer of your sound
card for details.
Make sure your sound card supports the same amount of channels as
your speaker system contains. For 4.1 systems, it should have a front
and rear speaker jack on the card. For 5.1 systems, the card should
have a front, rear, and center/sub, output. The card should be properly
installed and configured. Please contact your sound card manufacturer
for details. If you do not have a surround sound capable sound card,
you can use the M3D button on the controller unit (if you own a z-560
or z-540) or use the source selector switch (if you own a z-5300 or
x-620). If you do not have any of the models above, you can use an
adapter to split the signal for the front and rear speakers. This type
of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase
this adapter at your local electronic store. Please refer to your
manual if you do not know if your speaker system can emulate surround
sound.
Try connecting the speakers to a portable sound device such as a
walkman or portable CD player. Plug the speakers into the headphone
jack, but make sure the volume is lowered so the speakers are not over
powered. You can do this for both the front, rear, center/sub speakers
to verify that they work. If the speaker system works on the walkman,
then you are experiencing a configuration issue with your sound card.
Please contact your sound card manufacturer.
Check the system Volume Control located in the System tray. Make
sure that the volumes are at a reasonable level and are not checked for
Muting.
Read your manual , there is a level setting for each channel as well as a test function. Also remember most media on pro-logic mode dont have to loud sound from the rear speakers. Only a forced mono mode may give you louder sound at the rear. Regards PSP
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
card for details.
you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300
or x-620). If you do not have any of the models above, you can use an
sound.
Muting.
I fixed the main problem. It has inputs, not labeled as such. one set right next to all the outputs labeled only aux.after plugging in to the TV outputs, and putting the unit on AUX, this was fixed. The surround speakers were harder to work out, After downloading the manual, I was able to get sound out of them, however at a lower level than all the others. Even following the speaker level adjustments in the manual, cant get more volume out of them...I'll keep trying.
Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
card supports the same amount of channels as your speaker system
contains. For 4.1 systems, it should have a front and rear speaker jack
on the card. For 5.1 systems, the card should have a front, rear, and
center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound
card, you can use the M3D button on the controller unit (if you own a
manual if you do not know if your speaker system can emulate surround sound.
device such as a walkman or portable CD player. Plug the speakers into
the headphone jack, but make sure the volume is lowered so the speakers
are not over powered. You can do this for both the front, rear, center/sub
speakers to verify that they work. If the speaker system works on the
walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
Muting.
There is a setting in the dvd player to up the rear speakers to a + setting you have to dig deeep somewhere in the speaker settings. mine did the same thing till I found it.
wireless sourround speakers are faint
