The codes should be in the owners manual. Otherwise go to the web site in the support area. Type in the printer model then look for error codes support.
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage. Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions Please rate the answer........
try to add some color profile in the color management for the printer.You can search the color profile by key word "color profile for photo shop for printing on epson stylus pro 10600"
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
00010014 Pressurization error
Ink supply pressure incorrect
Explanation
The pressure system is determined to be leaking then this message appears and printer is stopped when detection of pressure origin sensor is incorrect at power on initialization or ink supply.
Solution
1. Replace supply pump assembly (including pressure origin sensor solenoid).
2. Check for disconnected air tube.
