SOURCE: how to wire up 24v minn kota to batterys
if you are trying to wire the batteries for teh 24 volt motor then you need to connect the positive of one battery to the negative of the other battery. then connect the trolling motor to the remaining two terminal of the batteries.
if you are trying to connect the charger to the batteries then each battery should have its own set of wire coming from the charger.these wires should be connected to the batteries in a set not crossed between batteries.
