One side of your 240 volt connection is disconnected, most likely in the plug wire connection. The neutral and one leg of your 240 is working thereby your display still works since it runs of 120 volts. Happened to me I had one wire come loose from stress on the plug
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
