SOURCE: Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
SOURCE: frozen bose lifestyle 48 IV
turn off the accoustimas, unplug the power code from the accoustimas and the media center and leave it for 15 sec. Then, plug the power code onto the accoustimas and turn it on. then plug the power code of the media center on. Turn media center on.
hope this helps
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
SOURCE: How do I connect my iPod to Bose Lifestyle V20 System
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
SOURCE: Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
