SOURCE: I forget my nokia 2690
- To unlock you Nokia 2690 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
SOURCE: i forget the nokia 2690
The default code is 12345, if this does not resolve then you need to contact nokia for them to unlock it for you.
SOURCE: forget my security code for
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate and leave a short comment,that is your choice.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
SOURCE: nokia 2310 forget security code
There have been some reported cases where operators have changed security codes on some phones.
In these cases, the security code will be shown on the product information label on the box, usually close to the IMEI number. This number is not always marked as a security code.
If your phone was provided to you by your network operator, will not accept the code 12345, and you are certain that you have not changed it, then it is worth checking the product information label on the box before you go for the Care Point option, just in case.
SOURCE: i forget my nokia 2690
hi i am Chirag my phone nokia 2690 is locked please help me....
send me security code
i lose my security code
