Question about Microsoft Zune JS8-00001 Digital Media Player
My Zune 4gb screen does not charge,light up,or even appear on my computer. Its been like this for at least 2008 I looked up some info in the internet but nothing helped me.I don't know if the battery does not work any more or i just did something wrong.Please help I don't know what to do!
    Top Expert:
  • Microsoft Master
  • 64,797 Answers
I suspect the battery has failed in it being the age it is .
Posted on Apr 27, 2019
5 Suggested Answers
6ya staff
SOURCE:
yodiggity69
SOURCE: trouble charging my zune
I would say make sure you are in the right USB port. My laptop has 3 and only one of them will charge my mp3 player
Posted on Apr 12, 2008
Anonymous
  • 4 Answers
SOURCE: Frozen Zune
Turn it on: if it will stay powered up, hold down on the pad, and hold the back button at the same time: This will turn the device off, thus possibly fixing the problem. (for the record, holding up on the pad while pressing back will reboot the device, but I find this sometimes does not want to take, like in the situation you are having)
I may also suggest plugging it into any give USB port, letting it try to charge again, then, when you unplug it, do the reboot or turn off commands as described above.
Hope that this helps: I would think the system is off, since you say it "turned off" on you, and now when you start it up you get the "i need a charge" battery, but knowing how my 80 gig acts sometimes, it may THINK it is shutting of when it is not.
Posted on Oct 15, 2008
Anonymous
  • 3 Answers
SOURCE: ZUNE NOT WORKING! ONLY BLACK SCREEN! WONT CHARGE!
Listen everyone this is what happened to me and what I did. Let the battery drain completely (unplugged from computer). It usually takes 5 to 6 hours to drain completely.
Then plug back in and hold the back and down button at the same time. Zune should resume functioning afterwards. All that is needed is a recharge.
Posted on May 13, 2009
Anonymous
  • 5 Answers
SOURCE: My Zune 4gb won't sync with my software and will not charge
i had the same problem. if you have a wall charger plug it in to that and it turns right on or try to reset it. press the up and back buttons at the same time. DO NOT PRESS THE PLAY BUTTON WITH THE UP AND BACK BUTTON. IT MIGHT ERASE ALL YOU'RE media.
Posted on Nov 15, 2009
Zune 120 GB My Zune hasn't been used I bought it in 2008, still have the receipt and everything. So when I decided to put it in use... It won't turn on. the logo will come on the screen and it...
Unfortunately, batteries have a shelf life. If the player sat for three years without being charged, the battery is probably bad. The chemical reactions inside the battery continue, even when it's not charged.
My advice is to replace the battery if possible.
Jul 15, 2011 | Microsoft Zune JS8-00001 Digital Media...
How do I restore my devices firmware for my zune 30gb
How to restore your Zune device software:------------
When you restore your Zune device software, the startup partition and the data partition are removed and rebuilt. In addition to removing the Zune device software, this process also erases all audio, videos, podcasts, and pictures that are stored on the Zune device.
Warning To restore the Zune device software, you must have a Windows-based computer that has an Internet connection. That computer must have the Zune software installed. And you must be able to connect the Zune device to a USB port on that computer by using a Zune Sync Cable. Do not perform the following steps if you do not have any one or more of these things immediately available.
After you start to restore the Zune device software, you cannot again use the device until you complete all the steps. You will not receive any confirmation or warning on the Zune device after you start the following procedure.
To restore the Zune device software, follow these steps:
1. Set the Hold Switch to unlocked.
2. Press and hold the Back button at the same time as you press and hold the top of the Zune Pad. When the Zune device begins to power up, release the buttons.
3. Immediately after you release the buttons in step 2, press and hold the following special button combination, depending on your Zune model:• If you have the 4GB Zune, the 8GB Zune, or the 80GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune Pad and the Play/Pause button. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
• If you have the 30GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
Note "Clearing contents. Please wait" appears, followed by “Connect Zune to your PC."
4. After “Connect Zune to your PC” appears, connect the Zune device to the computer that has the current Zune software installed, and then update the device to the current Zune device software.
----------- Click this link directly for more troubleshooting:-- http://support.microsoft.com/kb/944909 -------- If error problem while restoring then click this link below:-- http://support.microsoft.com/kb/945278 ---------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 03, 2010 | Vacuums
What should i do if the back button on my zune 4gb stopped working?
Ok, I used to have this problem when I used to have a Zune 4GB. So what I did was look online what the problem is and I found out that it was a mechanical problem, and it only could be fixed by sending it in to Microsoft and writing a claim for your problem. Then they would fix it. But if your under warranty don't even send it in, they will charge you way to much money to fix the problem. But how I dealt with the situation was to put it on shuffle or I would (when its on) hold play/pause, lock it then unlock it and it was back to the main menu.
Jan 18, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I have a 30g Zune which has not been holding a charge for a couple of weeks. This morning the Zune powers up and then shuts off (even while plugged in). I tried the 'hold down the back button and up at the...
I am not sure if this is gonna work but, since you've tried all other steps why dont we give this a try too...LOL :-)
To troubleshoot this issue, try one or more of the following methods in the order in which they are listed:
  1. Let your Zune device charge for 30 minutes, then disconnect and reconnect the cable to turn on the player. It can take up to 3 hours to fully charge.
  2. Connect the Zune device to a different USB port on the computer. Use a USB port on the back of the computer. Do not use a USB hub.
  3. Use another supported high power source, such as an Xbox 360 console, a Zune AC Adapter, a Zune Car Charger, or a Zune FM Transmitter/Charger.
    Note These devices are sold separately.
  4. If you are connecting your Zune device to a mobile computer, make sure that the mobile computer is plugged in and is not running on battery power. Many mobile computers are configured to conserve power when they are running on battery power to extend battery life. This behavior may affect Zune device charging.
  5. If the Zune device is charging slowly, be aware that, for optimal charging, the Zune device requires at least 500 milliamps (mA) of power. Frequently, USB ports that are located on the front of a computer and on some USB hubs are low-power, 100-mA ports. Typically, the high-power, 500-mA USB ports are on the back of the computer. Additionally, when you suspend the computer or put the computer to sleep, high-power USB ports may be switched to low-power, 100 mA mode.
  6. If the device boots to the home screen but is still not charging correctly, continue with the "Home screen is displayed" steps in the following section.
    If the device continues to display the full-screen charging icon, continue with "Full-screen charging icon is displayed."
  7. If the battery in the device still does not charge correctly, visit the following Web site to sign in and register your device: http://service.zune.net (http://service.zune.net)
    At this Web site, you can submit a request for service if your device qualifies for service.
Dec 24, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I had a similar problem with my 30GB Zune. The first normal solution is to make sure that the USB port is providing enough power to the Zune to charge it by trying a different port or computer, but since your other Zune charges it is likely not the problem.
Other possibly solutions are performing a hard reset on the Zune (hold back and up until it resets), or allowing the zone to completely discharge and try again. In my case, none of these solutions worked and I was forced to send my Zune in for a new battery, which Microsoft was willing to replace for free.
Jul 29, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune won't respond to any key presses.
I would first allow the Zune to completely charge (the battery symbol should be full and green[i believe--it's been a while since I first got mine]).
I would then unplug the device and restart the computer. Once your computer has completely rebooted connect the device to the computer and see if it detects the device. It should work. Also you might try another USB port.
Jun 07, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune blank screen
have you updated it to the latest firmware? cause zune's had a major malfution to to this years "leap year" the time change/date change messed with the internal clock causing major malfunctions
May 28, 2009 | Microsoft Zune JS8-00001 Digital Media...
My zune screen wont appear
Try pressing BACK+LEFT+CENTER as it is coming on. Then reinstall the firmware.
hope this helps
chris
Dec 15, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune charging problems, hardware problems
I had a 30g w/same problem. I installed the Zune software from CD. Plugged the Zune into my USB jack and waited hrs for the full screen battery icon to go away. It never did. Here is what I did to fix it. I left the Zune disconnected until its battery drained and the lcd went dark. In this state, pressing the play/pause button, caused the full screen battery icon to appear briefly before the lcd went dark again. With the Zune disconnected from my xp pc, I ran Windows Update in express mode. I have Windows system restore and auto-update turned off and rarely update my pc, so I also took the opportunity to take a manual system check-point (so I could restore from the check-point if an update trashed my pc). I took and installed all the latest Windows updates. When it was done, I had all the latest security updates and IE 7. At this point I went to http://www.zune.net/en-us/products/zunesoftware/download.htm and downloaded the latest Zune software. I installed the Zune software update. I ran the new Zune software on my PC and found the device tab. NOW I connected the Zune to a USB port on the back of my PC. The full screen battery icon appeared on the Zune but nothing appeared in the Zune software. I left it this way for a few minutes. It occurred to me that I might get more power through the USB port if I turned off my other external USB devices, which I did. Within a few minutes, the Zune FINALLY came to life and a Zune splash screen appeared on the device. The device booted and was FINALLY recognized by the Zune software on my PC. Shortly after that I noticed that it already started synchronizing with my PC music collection. I figured it would charge up and download my entire collection (20gig) so I grabbed some sleep for a few hours. When I returned, the PC was asleep too. Unfortunately, the Zune was not charged and had stopped sync'ing. Not to be discouraged, I woke up the PC, exited the Zune software and left the device charging for an hour or so. When I returned, the device was about 80% charged. I quickly disconnected and played my first music video on the device!!!! I reconnected (the Zune software auto-launched) and left it sync'ing and charging for a while longer. When it was 100% charged, I disconnected and have been using it for a few hours. It was a long painfull road to get this thing setup, but it was WELL WORTH IT! I am already a huge fan of this device. In fact, I'm considering passing this one on to my wife so I can get the 80gig. Hang in there, it's worth it!!!!
PS: one sidebar -- I have noticed that the pc software will only sync about 800 songs in a session. I have simply been restarting the sync to get the next session going. At this point, I am fully synchronized and have 4.5 gig free.
Dec 27, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
110 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
 Mike M
Mike M
Marvin
Marvin
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
