The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available. There is also a link there that will show you how to remove the front panel to acess the hose on the pressure switch.
It could also be a bad water inlet valve. This exact problem happened to me and I suspected the water level switch at first. But when I measured voltage at the water valve and it hadn't closed, I knew I found the problem. Replacing this part http://www.appliancepartspros.com/part_d... fixed it.
