Canon PowerShot SD1000 Digital Camera Logo
Posted on Mar 08, 2017
I recently dropped my Canon PowerShot SD1000 Digital Elph and, I'm hoping I can repair it. The slide (to switch between Camera, Video and Review) is not functioning and the camera is stuck in review mode. The switch slides but, doesn't change to the different modes. I have taken the back panel of and, having a hard time figuring out if there is a piece that has broken off or what the slide catches on to change. Obviously without a camera to take pictures of it, I will have a hard time describing so, have found images on the web: http://www.geekpapa.com/arts/newscreen/scn2.jpg The angle on this is off but, it looks like there is a little black bit that sticks out of the piece right under where the slide is on the back cover. Mine does not have anything..i see a silver rectangular plate over black plastic but, no little lever extending out to the side of the silver plate. Nothing came out or was loose in the camera when I removed the back cover so, I am CONFUSED!!!!
4 Related Answers
Anonymous
  • Posted on May 12, 2008
SOURCE: My powershot SD1000 digital elph
well i just hit it really hard and shook it and then it started working again.
Anonymous
  • Posted on Nov 15, 2008
SOURCE: my canon powet shot sd1000
Press your "display" button to change from the viewfinder view to your LCD view!
zohail
Shoaib Rais
  • 1223 Answers
  • Posted on May 29, 2009
SOURCE: Fuji S5000 Switch on it goes to review
it might be
CCD FAILURE
CALL FUJI for FREE repairs u are eligible i got mine repaired free it is a known problem
Regards
Zohail
Anonymous
  • 11967 Answers
  • Posted on Sep 17, 2009
SOURCE: I have a Cannon SD1000 stuck in revie mode. My daughter pulled it
Google the words...disassemble a digital camera.
My cameras power seems to work but the screen is all pur black ?? what can i do to fix this???
I have canon power shot sd1000 camera. Every thing is o.k. except that recently the screen stays dark in picture mode and when on for taking pictures. pl let me know.
2answers
If this was indeed dropped STOP! take it to a camera shop so they can do the repairs as you could damage other parts in the camera.
What could have happend when she dropped the camera the sensor inside got stuck into position to protect it from further damage. My advice is spend a couple bucks and take it in you be glad you did!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
My SD630 will not allow me to review pictures.
The mode switch malfunction. Try to open the camera, drop some alcohol to clean the switch.
3helpful
Powershot SD1000 automatically shuts down in Camera mode
In any mode that the camera will stay on, press the "Menu" button and navigate to the RESET option and try to reset the camera. See if this will get the camera to function properly.
CANON SD1000 can't TURN vertical downloaded video into horizontal
If you have windows movie maker (its part of the default installation of windows XP) you can use the rotate filter in the video effects tools.
Import your video into movie maker and select "Video Effects" under tools.  Scroll through the various effects until you find the "rotate 90".  Apply the effect and save the video.
I hope this helps!
4helpful
Card locked
Have you tried looking at the memory card? Sometimes there is a switch on the card itself that slides up and down to lock, or unlock the card for usage. Hope this helps! (It should be white, and a semi-translucent plastic.)
Canon powershot SD1000 digital
your question make no sense obivously your water in your camera please put a better question so i can help
Can't switch from photo taking to photo review
Assuming your LCD still works, go to the camera settings and reset the entire camera to the default factory settings. This will help you determine if it is a hardware or software problem. If you are still unable to get into the photo review, you may have a hardware problem.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
