Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Thanks. Are you referring to the Motor Fan (looks like a turbine in the middle with 2 black covers on each side) that is visible when the top vent cover is removed to change the charcoal filter? If so, do I have to un-install the microwave bolted into the cabinet to access it? Thanks.
The model is MH3184XPS (Stainless Steel)
