Sony HDR-SR10E HDD Camcorder Logo
Posted on Sep 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I accidently formated the hard disk of HDR-SR10E and system files are missing now.Now while boot up, LCD displays HDD format error. how could I re load the deleted files in to the hard disk again and restore the camcoder to original.?
Tony Parsons
Level 3:
  • Sony Master 6,405 Answers
  • Posted on Jun 06, 2019
Tony Parsons
Sony Master
Level 3:
Answers
6405
Questions
Helped
1650514
Points
20272
Reload the system from either the original disks, or your backup disks (you did backup the system, didn't you ?).
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
641
Points
You trough the camera
I need software download
hi,
just googled it from here in france :
HDR-SR10E and found that :
http://www.sony.fr/support/fr/product/HDR-SR10E
try in your location or download to see if multilingual !
cheers,
mich
tip
Sony HDR-SR10E,Share Sony HDR-SR10E MTS to FLV for Mac Users Do you have some...
Do you have some short films shot with Sony HDR-SR10E AVCHD camcorder, and want to share them on your website? It will make your site more attractive with videos. While Apple compete with Adobe, the Flash support on Apple devices like iMac, MacBook Pro do not support exporting to Flash FLV/SWF now. You can not directly export FLV from the Apple QuickTime Player, iMovie or Final Cut Pro/Final Cut Express.
One solution is to upload videos to YouTube and embed YouTube videos on your site. If you do not want to embed YouTube videos, you can convert Sony HDR-SR10E MTS files to FLV with Mac Sony MTS converter, and put the FLV videos on web server with Flash player. Aunsoft MTS/M2TS Converter for Mac is the recommended Mac Sony HDR-SR10E MTS converter for you. It exports Flash videos with automatic deinterlacing function, which makes the FLV videos play without interlacing artifacts. It could also help you merge several Sony .mts video clips and export as one file.
Here is the step-by-step guide to convert Sony HDR-SR10 videos to Flash on Mac.
Step 1. Load Sony HDR-SR10E videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-SR10 converter, and click the "Add" button to load .mts files for conversion.
Step 2. Choose Flash FLV output format.
Click the "Format" option, and choose Flash Video > FLV-Flash Video Format(*.flv) as output format. You can also choose the profiles like FLV H.264(*.flv) or F4V(/f4v).
Tips:
With The above mentioned output, you shall use Flash player like JW player, Moyea PlayerBox player, or Flow player to play the Flash videos. If you want the video to play automatically, you may choose SWF-SWF Forma(*.flv) as output.
Step 3. Transcode Sony HDR-SR10 MTS to Flash.
Click the "Convert" button under the preview window, and the conversion from Sony MTS to Flash video FLV/SWF will start right away.
Wait for a while, and you can upload the Flash videos to your sever and embed them on your web page.
PS:
1. The "Merge into one file" on the main interface is to join/splice .mts files.
2. If you are using camcorders like Sony HDR-CX350, HDR-XR520, HDR-TG7, or Cyber-shot DSC-TX7, DSC-H5V, you can also use the Mac Sony MTS converter to export FLV files for web sharing. Aunsoft MTS/M2TS Converter for Mac also works with Canon HF S21, Canon HF100, Panasonic HDC-TM700 and other AVCHD camcorders.
on Jul 22, 2010 • Cameras
How to undo formatting of harddisk of sony Handycam Camcorder HDR-SR10E
If you once started formatting and change your mind while in process you only have one chance: Switch off your cam! If this doesn´t work, put off the battery. It´s the hard way and you might have damaged the last file but might have rescued the rest.
Best wishes
Norbert
2helpful
3answers
My laptop lenovo ideapad y450 shows blue screen error.i tried to format with windows xp also,but it appears once format was completed also.advice me pls
Dear! Delete your C drive and create again with the help of windows and then format and install Windows. Your problem will be fixed.
4helpful
2answers
After I formatted using windows explorer Hard drive of Sony handycam ( HDR-XR500VE) message HDD FORMAT ERROR POPPING UP. How to resolve, please?
You need to format camcorder hard drive through Format option in camcorder menu itself.
Please check camcorder menu and hard drive section for Format option, this will delete all files on hard drive and solve your problem.
Thanks.
1helpful
Hi,my ps3 is saying, the hard disk's file system is corrupted and will be restored. the it says press ok. after i press ok, then it says restoring the system, after that it restarts it goes back to the...
here's some ideas:
________________________
I fixed my ps3!! All you need is a friend with a ps3!! Swap the hdd's and boot up your friends ps3, format the hdd, put it back in your ps3 and you may need to format it again.
_______________________________________________________
I tried to fix my friend's PS3 HDD that way in mine...it still gave an error every time he booted up his PS3. At that point I stuck the PS3 HDD in my laptop, booted from a Windows CD and fully formatted it that way...stuck it back in his machine...used it to format....finally got his stuff going. Took a little extra time but no problems since.
19helpful
5answers
2answers
Msdos problem
thats cause you are running the wing 98 of the same hard drive that you are trying to format. What you need to do is create a boot disc. boot from that disc and then format.
you can also boot from a win 98 cd to format as well.. If you have problems doing that let me know and i can walk you through it :)
4answers
PC halts while formatting hard drive
make sure your hard disk is error free Try formating the disk with FAT first ,if it doesn't work out the try disk utilities .
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
