Sceptre X20g-Naga III 20.1" LCD Monitor Logo
Posted on Sep 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does the Little Green Light on the front of my Monitor just Blink and the Monitor will not come on ?
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Sep 18, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2555642
Points
31058
The monitor is not getting any "signal" from the video-card.
Check that the video-cable is connected to both the monitor and to the video-card.
Try connecting the monitor to a different desktop/laptop,
to see if the monitor works "elsewhere".
Try connecting a different monitor to your desktop, to see if the video-card is the problem.
3helpful
Dell poweredge t110 server Amber error light on front panel blink one time
Had the same thing happen to me today and in my case it was a code 18 as they come...
It started while I was installing a video card adapter for a dual monitor setup. The solution - I had to simply close the side panel I had left open for testing and then reboot the server. The intrusion alarm went off.
I have samsung syncmaster 940mw monitor. The monitor for the most part will not turn on. When the power button is pushed or attempt to turn on with the remote the little green pilot light will blink or...
That is a hell know problem with the 940MW tv/monitors. The power supply has failed because of parts called capacitors have shorted. If you can solder then you should be able to repair your monitor. Here is a link to the repair guide for this issue.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/
I hope this helps, if so please rate my solution.
1helpful
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
1helpful
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
1helpful
Front panel lights blink on/off once per second
Hey,
I would like to agree to the diagnosis that you have done on the monitor . Thanks for a well complied solution. You can try the following website
http://werepairmonitors.com/monitor-repair.htm
dell generally sources the monitors from NEC,Hitachi or LG.
Thanks
proton
6helpful
3answers
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Monitor problems
It seems that you are trying to use a graphic mode that your monitor doesn't support.
Restart windows in safe mode, go to Control Panel. Click on Display. Select settings and change to a resolution that is supported by your monitor (I don't know your model, but 1024x768 is a safe bet).
Restart the computer.
It should be working by now.
Sharp LC-37D4U, the monitor doesn't turn on
It is hard to say without first looking at it.
3answers
Blinking green power on
1. remove your RAM and clean it and re fix it on motherboard if its just that problem it may come up.
2. try other RAM from any working PC to ensure your RAM is serviceable.
Top Sceptre Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
